Error Saplogon Miniwas
HOLA A TODOS,
YO SIGO CON MIS PROBLEMAS CON EL MINIWAS..., CONSEGUIRÉ ALGÚN DIA PODER TRABAJAR CON EL??? HE CONSEGUIDO, POR FIN, INSTALAR TODO EL MINIWAS, PERO AHORA CUANDO ACCEDO AL SAPLOGON ME SALEN ERRORES POSIBLEMENTE POR EL START SAP ABAP ENGINE, YA QUE CREO QUE NO FUNCIONA CORRECTAMENTE... ESTO ES LO QUE ME MUESTRA LA VENTANA DE MS-DOS: C:\MiniWAS> REM start SAP System C:\MIniWAS>rem del pxastat C:\MiniWAS>start /B msg_server.exe pf=BSP_D00.pf1 C:\MiniWAS>disp+work.exe break pf=BSP_D00.pf1 dp Ctrl-C enabled rslgwr1 (21): Searching for overlap point in pre-existing SysLog file... +**hasta aqui todo como indica el manual de instalación q viene en el CD**+ +**a partir de aqui aparecen unos errores de reloj que no entiendo **+ maximum pfclock time: 4294sec (1) adjust_clock: delta 4206 *** WARNING => pfclock may be dably adjusted (4206) dp Ctrl-C enabled dp Ctrl-C enabled gw Ctrl-C enabled dp Ctrl-C enabled maximum pfclock time: 4294sec (1) maximum pfclock time: 4294sec (1) maximum pfclock time: 4294sec (1) maximum pfclock time: 4294sec (1) adjust_clock: delta 408161 adjust_clock: delta 45403 adjust_clock: delta 46525 adjust_clock: delta 48139 adjust_clock: delta 46038 adjust_clock: delta 45934 adjust_clock: delta 43757 adjust_clock: delta 45501 adjust_clock: delta 32008 adjust_clock: delta 45478 *** WARNING => pfclock may be dably adjusted (408161) *** WARNING => pfclock may be dably adjusted (32008) adjust_clock: delta 21238 *** WARNING => pfclock may be dably adjusted (21238) adjust_clock: delta 19461 *** WARNING => pfclock may be dably adjusted (19461) IcmHandleArgs: Illegal option break ***ICM up and operational (pid: 2732) *** adjust_clock: delta 19713 adjust_clock: delta 19421 adjust_clock: delta 14297 *** WARNING => pfclock may be dably adjusted (14297) Y aqui se queda..., en realidad, segun el manual la única linea que me faltaría por aparecer es "Database table TCPDB empty. Guessing! See note 42305" y todos esos WARNINGs y ADJUST_CLOCK sobrarian... No se a que puede ser debido... A parte cuando intento acceder al sistema a traves del SAPLogon, me sale un pop-up con el siguiente mensaje: "The context management library could not be initialized", acepto y aparece otro: "Imposible lanzar 'fewfront.dll' (rc=183): No se puede crear un archivo que ya existe." Y aqui me quedo, a ver si alguien sabría como puedo solucionar esto...gracias! Salu2!! |
Hola Beyta82,
He estado consultando en el sdn de sap y he encontrado a una persona que le daba un error parecido: C:\MiniWAS>disp+work.exe break pf=BSP_D00.pfl dp Ctrl-C enabled rslgwr1(21): Searching for overlap point in pre-existing SysLog file... maximum pfclock time: 4294sec (1) gw Ctrl-C enabled dp Ctrl-C enabled dp Ctrl-C enabled dp Ctrl-C enabled maximum pfclock time: 4294sec (1) maximum pfclock time: 4294sec (1) maximum pfclock time: 4294sec (1) maximum pfclock time: 4294sec (1) adjust_clock: delta 2412 IcmHandleArgs: Illegal option break adjust_clock: delta 2192 adjust_clock: delta 747 *** ICM up and operational (pid: 2200) *** y el tío consiguió evitarlo desinstalando el MINIWAS y volviéndolo a instalar pero en lugar de la unidad c: en la unidad d: No se si te hes de ayuda :p , pero intenta algo del estilo. Un saludo :D |
A Seguir Intentandolo...
Muchas gracias...pues volvere a desinstalar...
Yo la verdad es q lo instalé en la unidad D, pq tenía el sistema de ficheros en FAT32 en lugar de NTFS y por no cambiar la unidad C, cambié solo la D a NTFS, puede que necesité cambiar a NTFS todos los discos...no se... Seguiré intentandolo...muchísimas gracias!!! |
Husos Horarios son GMT. La hora en este momento es 09:46:43. |
