ERROR Database Instance SAP IDES4.71
Hola!
Tengo un problema en la instalación con SAP IDES 4.71 y la verdad no sé que puede ser. Lo re-instalé 10 veces y aún no consigo pasar la última parte, ya que me arroja el siguiente error luego de seleccionar los paquetes EXPORT. ------------------------------------------------------------------------- Adjunto log: INFO 2009-11-25 00:15:37 Processing of host operation t_HostInfo_SHARED succeeded. INFO 2009-11-25 00:15:45 The 'saploc' share exists at directory 'C:\usr\sap'. Choosing drive C: as SAP System drive. INFO[E] 2009-11-25 00:16:18 Account group="p3lao\SAP_LDAP" does not exist. <#1> INFO[E] 2009-11-25 00:16:36 Account group="p3lao\dbc11ctl" does not exist. <#1> INFO 2009-11-25 00:19:23 Copying file C:/Varios/disk1/EXPORT1/DB/ORA/DBSIZE.XML to: DBSIZE.XML. INFO 2009-11-25 00:19:23 Creating file C:\SAPinst ORACLE SAPINST\DBSIZE.XML. INFO 2009-11-25 00:19:23 Copying file system node C:\Varios\disk1\EXPORT1/DB/ORA/DBSIZE.XML with type NODE to DBSIZE.XML succeeded. INFO 2009-11-25 00:19:23 Processing of all file system node operations of table tORA_filecopy succeeded. INFO 2009-11-25 00:19:24 Copying file C:/Varios/disk1/EXPORT1/DB/DDLORA.TPL to: DDLORA.TPL. INFO 2009-11-25 00:19:24 Creating file C:\SAPinst ORACLE SAPINST\DDLORA.TPL. INFO 2009-11-25 00:19:24 Copying file system node C:\Varios\disk1\EXPORT1/DB/DDLORA.TPL with type NODE to DDLORA.TPL succeeded. INFO 2009-11-25 00:19:24 Processing of all file system node operations of table tORA_filecopy succeeded. INFO 2009-11-25 00:19:28 Moving file C:/SAPinst ORACLE SAPINST/DDLORA.TPL to: orig_ddl_ora_tmp.tpl. INFO 2009-11-25 00:19:28 Moving file C:/SAPinst ORACLE SAPINST/changed_ddl_ora_tmp.tpl to: DDLORA.TPL. INFO 2009-11-25 00:19:28 Removing file C:/SAPinst ORACLE SAPINST/orig_ddl_ora_tmp.tpl. ERROR 2009-11-25 00:20:50 MSC-01002 Couldn't create package table, no packages found in: C:\Varios\disk1\EXPORT1 C:\Varios\disk2\EXPORT2 C:\Varios\disk3\EXPORT3 C:\Varios\disk3\EXPORT4 C:\Varios\disk3\EXPORT5 C:\Varios\disk3\EXPORT6 C:\Varios\disk3\EXPORT7 ERROR 2009-11-25 00:20:50 FJS-00012 Error when executing script. ERROR 2009-11-25 00:20:50 FCO-00011 The step fillR3loadPackageTable with step key SAPSYSTEM|ind|ind|ind|ind|ind|0|SAPComponent|ind|ind|ind|ind|ind|0|DatabaseLoad|ind|ind|ind|ind|ind|0|fillR3loadPackageTable executed with status ERROR. -------------------------------------------------------------------------- Para la instalación he seguido el manual en PDF disponible en esta Web -> Si alguien me puede ayudar sería excelente ya que he gogleado bastante pero no he encontrado exactamente el mismo error. Saludos Cocke |
Husos Horarios son GMT. La hora en este momento es 05:41:28. |
