Mandar Mails desde SAP
Buenos días, me han encomendado realizar un report que únicamente envíe un mail con un título y un texto. No he trabajado nunca con mails por lo que agradecería vuestra ayuda. Gracias por adelantado.
Un saludo. |
puedes utilizar esta función, pero sin el objbin que no te hace falta:
doc_chng-obj_descr = 'test'. objtxt = 'Texto adicional.'. APPEND objtxt. DESCRIBE TABLE objtxt LINES tab_lines. READ TABLE objtxt INDEX tab_lines. doc_chng-doc_size = ( tab_lines - 1 ) * 255 + STRLEN( objtxt ). objpack-body_start = 1. objpack-head_start = 1. objpack-head_num = 0. objpack-body_num = tab_lines. objpack-doc_type = 'RAW'. objpack-obj_name = 'body'. objpack-obj_descr = 'Texto'. objpack-doc_size = ( tab_lines - 1 ) * 255 + STRLEN( objtxt ). APPEND objpack. loop at t_all_spool. *if first = 'X'. * objpack-body_start = 1. * clear first. *else. objpack-body_start = tab_lines + 1. *endif. t_spool[] = t_all_spool-spool[]. append lines of t_spool[] TO objbin[]. * Esta es la lista DESCRIBE TABLE objbin LINES tab_lines. * Datos adjuntos objpack-transf_bin = 'X'. objpack-head_start = 1. objpack-head_num = 0. objpack-body_num = tab_lines. objpack-doc_type = 'ALI'. objpack-obj_name = 'Datos adjuntos'. objpack-obj_descr = 'spool ABAP'. READ TABLE objbin INDEX tab_lines. doc_size = ( tab_lines - 1 ) * 255 + STRLEN( objbin ). objpack-doc_size = doc_size. APPEND objpack. endloop. . reclist-receiver = 'direccion@gmail.com'. reclist-rec_type = 'U'. RECLIST-EXPRESS = 'X'. RECLIST-REC_DATE = sy-datum. APPEND reclist. CALL FUNCTION 'SO_NEW_DOCUMENT_ATT_SEND_API1' EXPORTING document_data = doc_chng PUT_IN_OUTBOX = 'X' COMMIT_WORK = 'X' * IMPORTING * SENT_TO_ALL = * NEW_OBJECT_ID = tables packing_list = objpack OBJECT_HEADER = objhead CONTENTS_BIN = objbin CONTENTS_TXT = objtxt * CONTENTS_HEX = * OBJECT_PARA = * OBJECT_PARB = receivers = reclist EXCEPTIONS TOO_MANY_RECEIVERS = 1 DOCUMENT_NOT_SENT = 2 DOCUMENT_TYPE_NOT_EXIST = 3 OPERATION_NO_AUTHORIZATION = 4 PARAMETER_ERROR = 5 X_ERROR = 6 ENQUEUE_ERROR = 7 OTHERS = 8 . IF sy-subrc <> 0. MESSAGE ID SY-MSGID TYPE SY-MSGTY NUMBER SY-MSGNO WITH SY-MSGV1 SY-MSGV2 SY-MSGV3 SY-MSGV4. ENDIF. |
dudas
Esto te sirve para enviar mails a SAP o al Outlook? Lo que me interesa es que sean enviado al Outlook.
Gracias |
correo
Hola, esa funcion envia correo a la direccion que ingreses, sea outlook, u otros....aqui un post similar..
:D |
Husos Horarios son GMT. La hora en este momento es 06:00:48. |
