Mensaje de sistema 06152
Hola, estoy configurando el mensaje 06152 como Error (esta en warning) desde spro-Gestión de materiales-Compras-Datos de entorno-Especificar propiedades de mensajes de sistema, y no me lo esta tomando en las solicitudes de pedido..., me sigue quedando como warning...
que puede ser??? Saludos.- |
Mensaje 06152
Esta fue la respuesta de a una note que se coloca en SAP en relacion a este problema.
09.01.2008 - 22:53:10 CET****SAP****Reply Dear customer: The message 06152 is a hard-coded Warning message and it cannot be configured as an Error message in OME0. There are certain cases where making this message appear as an error would make sense, but there are customers who want to be able to delete a Requisition item despite the fact that there has been a Purchase Order created against it. Thus, an Error message would be too strict. Therefore you only have the possibility to modify the program (e.g. by changing the line MESSAGE W152 to MESSAGE E152). Please be aware that this is considered a modification, and will not be supported by SAP. There had already been a development request regarding this subject, but our development department rejected the realization of this request with the following statement: ... There is no technical need for an error message. Also from a business point of view there is no need for an error message. The user does just the same, the archiving program will do after a while. The process is well documented, so it is visible that the deletion is done after the requisition is purchased. ... I hope this explains clearly how the standard system is designed. Please close this message by confirming it. |
Husos Horarios son GMT. La hora en este momento es 02:19:03. |
