sap ccms check database
Hola a todos, al intentar ejecutar un checkdb por la db13 inmediatamente me genera el error que muestro abajo, mi BD es SQL Server 2005 y sap ECC 6.0.
Alguna idea? Saludos. exec msdb..sp_add_job @originating_server = '(local)',@job_name = "SAP CCMS Check Database D01 [20080804093731-1-093731]",@enabled = 1,@description = "SAP CCMS JOB",@start_step_id = 1, @category_name = NULL,@category_id = NULL exec msdb..sp_add_jobstep @job_id = null,@job_name = 'SAP CCMS Check Database D01 [20080804093731-1-093731]',@step_id = 1,@step_name = 'CCMS-Step1 ',@subsystem = 'TSQL',@command = 'declare @exeStmt nvarchar(2000) exec d01.sap_new_dbcheck @dbName="D01",@outputfile="$(ESCAPE_NONE(SQLDIR)) \CCMS_CHECK_DB_HIST_2008.txt",@bkupSim = "Y",@exeStmt = @exeStmt OUTPUT',@database_name = 'D01',@output_file_name = '$(ESCAPE_NONE(SQLDIR))\CCMS_CHECK_DB_HIST_2008.txt',@flags = 2 dbcc checkdb( D01 ) with no_infomsgs exec msdb..sp_add_jobschedule @job_id = null,@job_name = 'SAP CCMS Check Database D01 [20080804093731-1-093731]',@name = 'CCMS-sche1',@enabled = 1,@freq_type =1,@freq_interval = 1,@freq_subday_type = 0,@freq_subday_interval = 0,@active_start_date = 20080804,@active_start_time = 93731 ,@freq_recurrence_factor = 0 exec msdb..sp_add_jobserver @job_name = 'SAP CCMS Check Database D01 [20080804093731-1-093731]',@server_name = '(local)' |
intenta lanzarlo desde el SO: brconnect -u / -c -f check, puede que sean permisos del usuario de windows SAPService<SID> |
Husos Horarios son GMT. La hora en este momento es 19:49:02. |
