Problemas De Instalacion Minisap Netweaver 7.0
QUE TAL BUENAS TARDES, VUELVO A POSTEAR PORQUE TENGO UN PROBLEMA CON LA INSTALACION DEL MINSAP, HE PROVADO INSTALARLO YA UNAS 15 VECES Y SIEMPRE ME DICE LOS MISMOS LOGS DE ERRORES, TENGO INTALADA LA MAQUINA VIRTUAL DE JAVA 1.4_2_8 Y CREE LAS VARIABLES DE ENTORNO DE ESTA FORMA:
NOMBRE DE LA VARIABLE: JAVA HOME VALOR DE VARIABLE: C:\J2SDK_1.4_2_8 TAMBIEN AVERIGUE QUE HAY QUE BORRAR UNA CARPETA DE INSTALL SHIELD QUE SE ENCUENTRA EN C:\ARCHIVOS DE PROGRAMA\ARCHIVOS COMUNES\INSTALL SHIELD PORQUE A VECES SE CREAN CONFLICTOS CON LA INSTALACION DEL MINISAP, OTRA COSA, CAMBIE EL NOMBRE DE MI PC A UNO CON MENOS DE 13 CARACTERES COMO PIDE LA INSTALACION PERO NO SE PORQUE SIEMPRE QUE LO QUIERO INSTALAR SE TERMINA DE INSTALAR BIEN PERO CUANDO PONGO SIGUIENTE ME DICE COMO QUE FALTA UN ARCHIVO Y ME DICE QUE SE DETALLARON LOS SIGUIENTES LOGS DE ERRORES Y SIEMPRE EL MISMO. LA VERDAD ESTOY DESESPERADO, PORQUE NO SE QUE HACER Y NECESITARIA CUANTO ANTES INSTALARLO, AGRADECERIA CUALQUIER TIPO DE AYUDA, MUCHAS GRACIAS. ACA DEJO LOS LOGS DE ERRORES: (Jun 11, 2008 8:17:41 PM), Install, com.sap.installshield.sdcstepswrapper.StepWrapperI nstallFiles, err, An error occurred and product installation failed. Look at the log file C:\SAP\NSP\log.txt for details. (Jun 11, 2008 8:17:41 PM), Install, com.sap.installshield.sdcstepswrapper.StepWrapperI nstallFiles, err, ProductException: (error code = 200; message="Java error"; exception = [java.lang.Exception]) STACK_TRACE: 15 ProductException: (error code = 200; message="Java error"; exception = [java.lang.Exception]) at com.sap.installshield.sdcstepswrapper.StepWrapperI nstallFiles.execute(StepWrapperInstallFiles.java:2 54) at com.sap.installshield.sdcstepswrapper.StepWrapperI nstallFiles.executeAllSteps(StepWrapperInstallFile s.java:224) at com.sap.installshield.sdcstepswrapper.StepWrapperI nstallFiles.executeAllInstallationSteps(StepWrappe rInstallFiles.java:177) at com.sap.installshield.sdcstepswrapper.StepWrapperI nstallFiles.install(StepWrapperInstallFiles.java:2 68) at com.installshield.product.service.product.PureJava ProductServiceImpl.installProductAction(Unknown Source) at com.installshield.product.service.product.PureJava ProductServiceImpl$InstallProduct.getResultForProd uctAction(Unknown Source) at com.installshield.product.service.product.Installa bleObjectVisitor.visitComponent(Unknown Source) at com.installshield.product.service.product.Installa bleObjectVisitor.visitInstallableComponents(Unknow n Source) at com.installshield.product.service.product.Installa bleObjectVisitor.visitProductBeans(Unknown Source) at com.installshield.product.service.product.PureJava ProductServiceImpl$InstallProduct.install(Unknown Source) at com.installshield.product.service.product.PureJava ProductServiceImpl$Installer.execute(Unknown Source) at com.installshield.wizard.service.AsynchronousOpera tion.run(Unknown Source) at java.lang.Thread.run(Unknown Source) (Jun 11, 2008 8:22:42 PM), Install, com.installshield.product.service.product.PureJava ProductServiceImpl$InstallProduct, err, An error occurred and product uninstallation failed. Look at the log file C:\SAP\NSP\log.txt for details. (Jun 11, 2008 8:22:42 PM), Install, com.sap.installshield.sdcstepswrapper.StepWrapperI nstallFiles, err, ProductException: (error code = 200; message="Java error"; exception = [java.lang.Exception]) STACK_TRACE: 15 ProductException: (error code = 200; message="Java error"; exception = [java.lang.Exception]) at com.sap.installshield.sdcstepswrapper.StepWrapperI nstallFiles.execute(StepWrapperInstallFiles.java:2 54) at com.sap.installshield.sdcstepswrapper.StepWrapperI nstallFiles.executeAllSteps(StepWrapperInstallFile s.java:224) at com.sap.installshield.sdcstepswrapper.StepWrapperI nstallFiles.executeAllUninstallationSteps(StepWrap perInstallFiles.java:192) at com.sap.installshield.sdcstepswrapper.StepWrapperI nstallFiles.uninstall(StepWrapperInstallFiles.java :313) at com.installshield.product.service.product.PureJava ProductServiceImpl.uninstallProductAction(Unknown Source) at com.installshield.product.service.product.PureJava ProductServiceImpl$InstallProduct.processActionsFa iled(Unknown Source) at com.installshield.product.service.product.Installa bleObjectVisitor.visitComponent(Unknown Source) at com.installshield.product.service.product.Installa bleObjectVisitor.visitInstallableComponents(Unknow n Source) at com.installshield.product.service.product.Installa bleObjectVisitor.visitProductBeans(Unknown Source) at com.installshield.product.service.product.PureJava ProductServiceImpl$InstallProduct.install(Unknown Source) at com.installshield.product.service.product.PureJava ProductServiceImpl$Installer.execute(Unknown Source) at com.installshield.wizard.service.AsynchronousOpera tion.run(Unknown Source) at java.lang.Thread.run(Unknown Source) GRACIAS POR SU TIEMPO. |
Error Al Instalar MiniSap NetWear
Saludos a todos los del Foro..
Haber si alguien puede apoyarme. Estoy intentado instalar el SAP Netwear Trials 7. directamente desde Internet, pero me visualiza la siguiente mensaje de error : "Java.lang.NoClassDefFoundError: run Exception in Thread "main"". Se agradece cualquier comentario y apoyo!.. Muchas gracias y saludos!! |
hola, mira tambien he tenido problemas para instalar productos de SAP que incluyen java y lo solucione, ingresa a esta pagina y revisalo.
tambien tienes que verificar que el JCE sea el correcto, para el JDK 1.4.2 revisa este link. al final de la pagina esta para bajarlo. Suerte.. |
Pon las variables de entorno del usuairo y globales al path de java - bin
Error de Instalacion de MiniSAP
Amigos del Foro estuve consultando sobre un error q tengo con la instalacion de minisap.-
y agregue a una persona del foro mundo sap su mail es : esta persona.- yo comense a explicar lo q me sucedia me indico lo siguiente para realizar para q mi problema se solucionara.- que eliminara la carpera system32 de mi windows.- cuando le indico q eso no es factible me responde q queria saber lo estudido que yo era por q le comente q era chile,,me dijo unos insultos y que era del terccer mundo por eso no sabia solucionar esos problemas.- espero q era persona sea ubicada por el administrador del foro y lo castique con la no coneccion en un foro serio y de ayuda no se gente como esa.- gracias.- |
Errores con netweaver: Java.lang.noclassdeffounderror: run Exception in thread
Para dpalma y demás
Llevo peleándome todo el día con esto hasta que creo haber dado con la solución... Probablemente sea tu caso que cuando ejecutas setup.exe lo haces una vez que tu navegador se lo ha descargado en el disco duro o cualquiera de las rutas que hayas configurado en tu navegador para la descarga. El caso es que no se necesita tener configurada la VM ni ninguna de las variables de entorno, ya que esta instalaciòn lleva incorporada la máquina virtual. Probablemente y esto, a lo mejor me lo invento, al ejecutarlo desde una ruta distinta a la configurada en el setup.exe busca en tu ordenador un path que seguro no puede existir... en resumen HAS DE EJECUTARLO DIRECTAMENTE en la carpeta /image. Probablemente sea E:\Sap...\image\setup.exe tu ruta exacta. Lo hice así y funcionó. |
Tengo El Siguiente Error Al Ejecutar
TCP/IP ERROR detected by Sapgui
Time Wed May 31 11:46:11 2006 Release 46D Component NI (network interface) Version 34 Return Code -1 Module ninti.c Line 1174 Detail NiPSocket System Call WSASocket Error No 10091 Error Text WSASYSNOTREADY: Network subsystem is unavailable Counter 2 |
simulador de SAp
Hola alguien tiene, un link donde pueda descargar algun simulador de SAP para practicar... se los agradeceria muxo... saludos q esten bien...
En el area de administracion hay un thread fijo donde explica eso. El buscador tambien trae excelentes resultados.
Tengo el mismo problema
Estimado; al instalar minisap y comenzar a ejecutarlo me sale exactamente el mismo mensaje de error. ¿Lo pudiste solucionar?, si es así, ¿me puedes indicar por favor cómo lo solucionaste? Atte. Pablo Canales |
Husos Horarios son GMT. La hora en este momento es 07:14:24. |
