Problemas con el backup online
Buenas a todos, gente estoy teniendo un problema con el backup online, aca les dejo el log de error, no pude encontrar nada al respecto, si me ayudan se los voy a agradecer!!!
BR0051I BRBACKUP 6.40 (47) BR0055I Start of database backup: bdxpayoy.anf 2008-03-30 12.17.08 BR0484I BRBACKUP log file: /oracle/TIQ/sapbackup/bdxpayoy.anf BR0280I BRBACKUP time stamp: 2008-03-30 12.17.08 BR0301E SQL error -942 at location BrDbConnect-4 ORA-00942: table or view does not exist BR0310E Connect to database instance TIQ failed BR0280I BRBACKUP time stamp: 2008-03-30 12.17.08 BR0301E SQL error -942 at location BrDbConnect-4 ORA-00942: table or view does not exist BR0310E Connect to database instance TIQ failed |
Bueno pues el error ORA-00942 es este segun la pagina ORACLE ...
ORA-00942: Table or view does not exist The table you are trying to access does not exists, or you do not have privileges to access the table. You can use following select to determine if you have access on the table: select owner, object_name, object_type from all_objects where object_name='<table_name> or <view_name>' If you do see the table/view in the previous select, you might need to add the owner in front of the table/view name. select * from owner.object_name If you have to add the owner in front of the name, you can consider creating a synonym. create synonym synonym_name for owner.object_name. From now on you can just select from the synonym name (which is usually the same name as the table/view name). If you do not have privileges on the table or view, grant the necessary privileges as the owner of the object: grant select on object name to privileged user Espero te sirva de ayuda ..... Saludos |
Husos Horarios son GMT. La hora en este momento es 14:05:34. |
