Error Desarrollo de Interfaz
Err.tmpo.ejec. CONVT_CODEPAGE
Excep. CX_SY_CONVERSION_CODEPAGE Fecha y hora 13.01.2010 16:07:59 Texto breve A character set conversion is not possible. ¿Qué ha sucedido? At the conversion of a text from codepage '4110' to codepage '4102': - a character was found that cannot be displayed in one of the two codepages; - or it was detected that this conversion is not supported The running ABAP program 'ZUNIXFBR' had to be terminated as the conversion would have produced incorrect data. The number of characters that could not be displayed (and therefore not be converted), is 9. If this number is 0, the second error case, as mentioned above, has occurred. ¿Qué puede hacer? Please make a note of the actions and input which caused the error. - To resolve the problem, contact your SAP system administrator. With transaction ST22 for the ABAP dump analysis, you can analyze and administrate termination messages, or store them for a longer time period. If you were requested by the application to enter a codepage, the termination may be avoided after the restart of the application if you enter a different codepage. If characters could not be converted: Please use transaction SCP to analyse the codepages used by you. Search for characters you wanted to convert, which are not entered in the table. (If you changed a codepage, you can use transaction SP12 to invalidate the character set buffer (CCC). You find further help tools to codepages in transaction SNLS. Anál.errores An exception occurred that is explained in detail below. The exception, which is assigned to class 'CX_SY_CONVERSION_CODEPAGE', was not caught in procedure "COLLECT_DATA" "(FORM)", nor was it propagated by a RAISING clause. Since the caller of the procedure could not have anticipated that the exception would occur, the current program is terminated. The reason for the exception is: Characters are always displayed in only a certain codepage. Many codepages only define a limited set of characters. If a text from a codepage should be converted into another codepage, and if this text contains characters that are not defined in one of the two codepages, a conversion error occurs. Moreover, a conversion error can occur if one of the needed codepages '4110' or '4102' is not known to the system. If the conversion error occurred at read or write of screen, the file name was '/home/anonimo/CI_ITEMS'. (further information about the file: "X 198 400554rw-rw-rw-201001131055432010011303543720100113090642") Notas para corregir errores If the error occures in a non-modified SAP program, you may be able to find an interim solution in an SAP Note. If you have access to SAP Notes, carry out a search with the following keywords: "CONVT_CODEPAGE" "CX_SY_CONVERSION_CODEPAGE" "ZUNIXFBR" or "ZUNIXFBR" "COLLECT_DATA" If you cannot solve the problem yourself and want to send an error notification to SAP, include the following information: 1. The description of the current problem (short dump) To save the description, choose "System->List->Save->Local File (Unconverted)". 2. Corresponding system log Display the system log by calling transaction SM21. Restrict the time interval to 10 minutes before and five minutes after the short dump. Then choose "System->List->Save->Local File (Unconverted)". 3. If the problem occurs in a problem of your own or a modified SAP program: The source code of the program In the editor, choose "Utilities->More Utilities->Upload/Download->Download". 4. Details about the conditions under which the error occurred or which actions and input led to the error. The exception must either be prevented, caught within proedure "COLLECT_DATA" "(FORM)", or its possible occurrence must be declared in the RAISING clause of the procedure. To prevent the exception, note the following: Info posición de cancelación Termination occurred in the ABAP program "ZUNIXFBR" - in "COLLECT_DATA". The main program was "ZUNIXFBR ". In the source code you have the termination point in line 165 of the (Include) program "ZUNIXFBR". The termination is caused because exception "CX_SY_CONVERSION_CODEPAGE" occurred in procedure "COLLECT_DATA" "(FORM)", but it was neither handled locally nor declared in the RAISING clause of its signature. The procedure is in program "ZUNIXFBR "; its source code begins in line 151 of the (Include program "ZUNIXFBR ". |
es un problema de unicode..
donde tengas open dataset, pone.. OPEN DATASET archivo FOR INPUT (o OUTPUT, depende de lo que tengas) IN ... MODE ENCODING DEFAULT Espero que te sea util.. Saludos! |
Gracias Amigo
Te puedo enviar a un mail el desarrollo me ayudas donde pls..soy pollo
gracias |
si, no hay problema! lo que si, hoy no te lo puedo contestar, pero para mañana, seguro!
Saludos! |
Amigo ok,,gracias
mira ,,dando una vuelta el codigo lo tiene pero asi.
906 * OPEN DATASET p_items FOR OUTPUT IN TEXT mode encoding default. |
Todo esto tiene con OPEN DATASET
841 *\ OPEN DATASET p_items FOR OUTPUT IN TEXT MODE.
854 OPEN DATASET P_ITEMS FOR OUTPUT IN BINARY MODE. 866 * OPEN DATASET P_ITEMS IN TEXT MODE FOR OUTPUT ENCODING NON-UNICODE. 879 * OPEN DATASET P_ITEMS IN TEXT MODE FOR OUTPUT ENCODING UTF-8. 895 OPEN DATASET p_items FOR OUTPUT IN LEGACY TEXT mode code page '1100'. 906 * OPEN DATASET p_items FOR OUTPUT IN TEXT mode encoding default. |
ok! lo mas probable que el error se encuentre en la linea 895..
primero proba reemplazar en la linea 895, lo que dice 'code page 1100' por 'encoding default'.. y luego fijate en la linea 854, de ponerle al final ENCODING DEFAULT.. Avisame a ver que tal salio! Saludos! |
Muchissssiiiiiiiiiimas gracias
Te pasaste probare,,gracias
de nada! cualquier cosa tenes mi mail!
Saludos! |
Mismo error pero en READ DATASET
Estimados
Se aplica la misma solucion para el DUMP en la línea con el Read Dataset ? READ DATASET v_header INTO hcont. ? Tendria que agregar para que quede READ DATASET v_header INTO hcont IN TEXT MODE ENCODING DEFAULT. ? Gracias |
Husos Horarios son GMT. La hora en este momento es 23:35:04. |
