Clonación ME47
Que tal,
Realice una copia de la transaccion ME47 a ZME47. esta marcando los siguientes errores: ******************************************************* Anál.errores A new value is to be assigned to the field "<BELEGPOS>", although this field is entirely or partly protected against changes. The following are protected against changes: - Character literals or numeric literals - Constants (CONSTANTS) - Parameters of the category IMPORTING REFERENCE for functions and methods - Untyped field symbols not yet assigned a field using ASSIGN - TABLES parameters if the actual parameter is protected against changes - USING reference parameters and CHANGING parameters for FORMs, if the actual parameter is protected against changes and - Accesses using field symbols if the field assigned using ASSIGN is protected (or partially protected, e.g. key components of an internal table with the type SORTED or HASHED TABLE) against changes - Accesses using references, if the field bound to the reference is protected (or partially protected) against changes - External write accesses to READ-ONLY attributes, - Content of a shared object area instance accessed using a shared lock (ATTACH_FOR_READ). ******************************************************** Cuando se quiere salvar la oferta, envia el mensaje El documento no contiene posiciones y no permite salvarlo. Cabe mencionar que si tiene posiciones: 10 300019 PAPEL PVC CRISTAL 157MM 250 MICRAS 300 KG T 01/11/2008 1 KG S00003 1200 1211 20 300020 PAPEL ALU GLILEX2/850 MM 155MM25MICRAS 28 KG T 01/11/2008 1 KG S00004 1200 1211 Alguien sabra si hay que dar de alta algo en alguna tabla?? o que hay que hacer????? Espero me puedan ayudar. Saludos y les mando un ABRAZO!!! |
Husos Horarios son GMT. La hora en este momento es 11:29:30. |
